2002 CRV help
Old Aug 10, 2023 | 07:13 AM
chriswhisenhunt's Avatar
Default 2002 CRV help
Where do I begin?!
Wouldn't turn over so I replaced the starter. I'm by no means mechanical but after getting the intake manifold off, starter in, everything back together (sort of) and having her crank right up, I feel like I can fix anything....While taking the intake manifold off, I found that the intake box was cracked in a few places. I found a used one on eBay, installed it yesterday and it still cranks, but while in park the RPMs start creeping up and then dropping back down to idle. A quick google search says that it could be a vacuum leak or a MAF sensor issue. Any thoughts?
Second, is there a manual anywhere for this engine on how to figure out what's what? I'm a software engineer and have a good sense of technical hardware/software, but need a little help in the mechanical space. Any and all help would be great.
Lastly, both the maintenance required and check engine light are on. How do I figure out what the check engine light on is for?
Old Aug 10, 2023 | 07:36 AM
Take a picture of the crack for us.
Old Aug 10, 2023 | 07:53 AM
I replaced the one with the crack in it.
Old Aug 10, 2023 | 08:46 AM
Put a can tool on it and get us the codes.
Old Aug 10, 2023 | 06:42 PM
P0661
P1505
P0505
A few things as I read about these online. When taking the intake off a some anti-freeze did leek out so after assembling everything I added some back. How do I check for a vacuum leak? A few of the electrical plugs did break on me when removing. I have them all seated and in place with zip ties until I can verify this thing is going to run a good bit longer, then I'll work on figuring out how to replace those.
Thanks again for the help! I'm learning a lot!
Old Aug 12, 2023 | 10:17 AM
A few new things have come up. I checked the IMRC and the sensor wasn't plugged in (one on the bottom). I plugged that in and then got the following four codes:
P0661
P1505
P0505
P1077 (this is new).
I cleared the codes then let the engine run for a few minutes and am now just getting 1077. It still starts and then revs which from what I've read says a vacuum leak. How do I check for that?
Old Aug 12, 2023 | 07:48 PM
You need a scan tool not a code reader.
Old Aug 12, 2023 | 08:09 PM
This is what I bought.
https://www.autozone.com/test-scan-a...ool/273349_0_0
Sorry for the dumb questions, not sure what’s the difference is.
Old Aug 12, 2023 | 09:23 PM
That link to AZ has about everything EXCEPT a scanner.
Old Aug 14, 2023 | 12:02 PM
  #10
A simple Google search will come up with many places to get access to CRV Gen 2 service manual.
Here is one. You can use it on line or download each section
https://procarmanuals.com/honda-cr-v...5-shop-manual/
zdshane
Sep 27, 2020 03:12 AM
ugotscooooped
Sep 30, 2019 06:45 PM
Mr.Dread
Feb 20, 2015 03:50 AM
cody480gsr
Mar 12, 2009 12:27 PM
Sharjite
May 25, 2008 03:52 PM
