2006 Crv A/c control
Old May 1, 2025 | 12:23 PM
Pnj2108's Avatar
Default 2006 Crv A/c control
So my a/c cools and it's super cold however the fan speed seems to only have 2 speeds like HIGH and a medium high. So after a while it just gets freezing so I try to divert the air to the floor vent + upper vents and after a while my feet are freezing. I have noticed that when I go about half way between off and high the fan lowers speed just a bit. On another note I notice that when I turn the know from the off position I have to turn like 3 click before the a/c even comes on which i thought was odd. I changed the resistor as a first step and no change so just wondering if anyone has any pointers.
Old May 1, 2025 | 02:58 PM
The temperature control don't work? Sounds like the switch is bad.
Old May 1, 2025 | 10:01 PM
Pnj2108's Avatar
I just tested both the a/c and the heater buti took a picture of the speed control know and where it is when the blower actually turns on.
Old May 2, 2025 | 01:58 PM
I have no idea what your problem is. Seems you are not sure yourself.
Old May 17, 2025 | 06:59 PM
Pnj2108's Avatar
Update i went to my local LKQ You Pull it junk yard and they happen to have an exact model to my crv it was even the same color as mine. I replaced the a/c control module and now my a/c works correctly on all speeds.
Michaelfiss
May 4, 2024 10:18 AM
jah
Jan 25, 2011 09:29 AM
johnfm3
Jul 19, 2009 02:42 AM
asroc12
Sep 24, 2006 02:43 AM
PW01
Aug 1, 2006 04:13 PM
