2008 CRV Climate Control System
Old Mar 12, 2022 | 04:52 PM
rparmer's Avatar
Default 2008 CRV Climate Control System
Got in the car this morning, cold temps and ice/snow on windshield. Cranked up and turned on defrost, heated seats, etc. All lights in climate control system went off along with heated seat lights. All other systems work. Any ideas/help would be greatly appreciated.
Thanks,
RP
Old Mar 12, 2022 | 07:45 PM
Did you check the fuse? Anything? Maybe take it to a shop.
Old Mar 12, 2022 | 08:01 PM
rparmer's Avatar
Which fuse?
Old Mar 13, 2022 | 02:25 PM
What's not working? Take it to a shop.
Old Mar 13, 2022 | 04:51 PM
rparmer's Avatar
Heat, AC, defrost, including rear window and heated seats are not working. I cannot find a specific fuse that is labeled for the Climate Control System.
Old Mar 13, 2022 | 10:20 PM
Hvac?
Old Mar 20, 2022 | 11:46 AM
Easy to check all fuses with a test light. Fuses have two test points on top. One for each side of the fuse.
Test light clip to ground. Probe to each test point. If both sides light up then fuse is good (vehicle must be on).
If only one side lights up the fuse is blown. If no lights then fuse is not powered up.
Make sure to test all fuses.
deeperblue
Jan 22, 2022 12:36 AM
npdion
Nov 12, 2021 09:40 AM
sbazain
Apr 20, 2017 03:33 AM
pilyin
Jan 18, 2017 03:27 AM
ablevins31
Mar 14, 2016 07:21 AM
