2008 Honda CRV - Codes P0420 / P0139 keep popping.
Old Nov 14, 2024 | 06:19 PM
CRVEric08's Avatar
Default 2008 Honda CRV - Codes P0420 / P0139 keep popping.
I bought this 2008 Honda crv new back in 08. Been a trouper. Just wondering if anyone else with an 08 CRV has issues with the P0420 catalytic converter code popping at random? The cars old so I don’t doubt the catalytic converter is close to dying but the fact that every few months it pops up, then goes away makes me feel like maybe it isn’t. I did buy the car in VA and now live in CO. Not sure if elevation could be messing with it? I assume also with the catalytic code it auto pulls the P0139 PCM rear oxygen sensor. If anyone else has had this happen would love to hear. Thank you.
Old Nov 16, 2024 | 11:13 AM
Operation CHARM: Car repair manuals for everyone.
Home >> Honda Truck >> 2008 >> CR-V 2WD L4-2.4L >> Repair and Diagnosis >> A L L Diagnostic Trouble Codes ( DTC ) >> Testing and Inspection >> P Code Charts >> P0139 >> DTC Troubleshooting
DTC Troubleshooting
DTC P0139: Secondary HO2S (Sensor 2) Slow Response
NOTE: Before you troubleshoot, record all freeze data and any on-board snapshot, and review the general troubleshooting information.
1. Turn the ignition switch ON (II).
2. Clear the DTC with the HDS.
3. Start the engine. Hold the engine speed at 3,000 rpm without load (in Park or neutral) until the radiator fan comes on, then let it idle.
4. Test-drive under these conditions:
- Engine coolant temperature (ECT SENSOR 1) above 176 °F (80 °C)
- Transmission in D position
- Vehicle speed between 35-55 mph (56-88 km/h)
- Drive 5 minutes or more
5. Monitor the OBD STATUS for DTC P0139 in the DTCs MENU with the HDS.
Does the screen indicate FAILED?
YES - Go to step 6.
NO - If the screen indicates PASSED, intermittent failure, the system is OK at this time. Check for poor connections or loose terminals at the secondary HO2S (Sensor 2) and the PCM. If the screen indicates EXECUTING, keep driving until a result comes on. If the screen indicates OUT OF CONDITION, go to step 3 and recheck.
6. Turn the ignition switch OFF.
7. Replace the secondary HO2S (Sensor 2).
8. Turn the ignition switch ON (II).
9. Reset the PCM with the HDS.
10. Do the PCM idle learn procedure.
11. Start the engine. Hold the engine speed at 3,000 rpm without load (in Park or neutral) until the radiator fan comes on, then let it idle.
12. Test-drive under these conditions:
13. Check for Temporary DTCs or DTCs with the HDS.
Is DTC P0139 indicated?
YES - Check for poor connections or loose terminals at the secondary HO2S (Sensor 2) and the PCM, then go to step 1.
NO - Go to step 14.
14. Monitor the OBD STATUS for DTC P0139 in the DTCs MENU with the HDS.
Does the screen indicate PASSED?
YES - Troubleshooting is complete. If any other Temporary DTCs or DTCs were indicated in step 13, go to the indicated DTCs troubleshooting.
NO - If the screen indicates FAILED, check for poor connections or loose terminals at the secondary HO2S (Sensor 2) and the PCM, then go to step 1. If the screen indicates EXECUTING, keep driving until a result comes on. If the screen indicates OUT OF CONDITION, go to step 11.
pro multis · About Operation CHARM
villefan24
Feb 8, 2023 09:51 AM
johno_84
Jan 22, 2023 08:00 AM
Chrischuck73
Mar 26, 2022 12:29 AM
Bluenarcotic
Jan 7, 2022 04:26 PM
pergojr
Aug 21, 2013 12:34 PM
