2016 Honda CR-V Transmission Fluid Change
Old Aug 19, 2019 | 12:28 AM
444samc's Avatar
Default 2016 Honda CR-V Transmission Fluid Change
Hello,
I just changed the transmission fluid in my girlfriends Crv and was hoping someone could help me with some questions I’m having.
I warmed the car up to normal operating temperatures and drained the fluid. I got about 4.25 quarts out when I drained it. But I only put 4 quarts back into the transmission. I then preformed the shift level procedure and with in 30 seconds of turning the engine off I removed the check bolt and 3 or 4 old drops of transmission fluid drained out. I then stepped away a for a min or two and when I looked down the fluid was running out at a steady stream. I know the transmission fluid is at the proper level when gradually dripping from the check hole, but how long does that take.
QUESTIONS:
1. After doing the shift level procedure and pulling the check bolt, how long do you wait for the oil to run out?
2. Was I too quick at pulling the check bolt (20-30 seconds)?
3. Shouldn’t the oil only run out if it’s too full, no matter how long you wait?
Just trying to figure out if it too low or full.
Thanks for your time and help,
Sam
Old Dec 1, 2019 | 07:11 PM
fonz623's Avatar
Originally Posted by 444samc
Hello,
QUESTIONS:
Sam
changed using correct fluid from dealer and amount specified...
car had 46500mi and 3.5yrs since new 2016 crv touring...
Did not do anything with checkbolts or whatever...
Will repeat in 3yr or at 100k... No problem..
nfinity
Jun 14, 2019 09:07 PM
joeblack1980
Jan 9, 2016 08:51 PM
prof.bart
Oct 28, 2012 09:07 AM
Rustyb
Jul 28, 2011 12:22 AM
mike0094
Oct 18, 2008 11:10 AM
