2018 CR-V Won't Start
Old Jan 27, 2021 | 11:25 AM
Mooni's Avatar
Default 2018 CR-V Won't Start
Hi I was wondering if anybody had the same problem as me. And how were they able to solve it at your workshop?
So my CRV wasn't able to start yesterday and I had it towed to my dealership. They told me it was cuz my battery is dead due to inactivity (but I drove it last week to somewhere far) and had my car up and going for me to drive home after they did all the diagnosis and concluded nothing was wrong with my car. Today, it happened again. I'm going to jump start the car in a bit to bring it to dealership again, but I wonder if anybody know what possible is wrong with my car in this situation? battery replacement maybe?
Old Jan 27, 2021 | 04:41 PM
Cause you are saying to jump the battery in order to start the engine, I assume no crank, no start
Starting system deals with battery, ignition switch, starter cut relay, park neutral safety switch, starter solenoid, starter motor
All the wiring in between and the grounds
If push button to start then also those electronics and brake switch
First thing I would do is to clean battery posts and cable terminals
Then follow negative cable to chassis ground and clean up grounding point
Then locate engine ground strap and clean those two points.
If no crank no start happens again then would try cranking engine with the gear selector in neutral
Try putting the gear selector through all the gears and try again
Could be a bad battery or could be faulty alternator not charging, or could be parasitic drain after engine is turned off
Old Jan 27, 2021 | 11:24 PM
welcome to the forum. before doing all kinds of trouble shooting, do a load test on the battery., the battery may be weak and slowly loosing its charge sitting not running daily. if it holds a charge, then do everything avisitor is advising.
Crv2019
Jan 10, 2021 03:41 PM
johna136
Jul 11, 2020 07:45 PM
Chris Grenier
Jun 8, 2019 01:23 PM
Asphaltwarrior
Dec 3, 2017 09:16 AM
