3 dash lights
Old Apr 10, 2026 | 06:08 AM
Powerplant's Avatar
Default 3 dash lights
2012 CRV EXL 2.4L
Blinking engine light
stability control light
steering wheel light
P0420 and P0303 codes
Anyone run into these 3 lights all coming on at the same time before?
Old Apr 10, 2026 | 07:06 AM
Just Ducky's Avatar
Default Secret Squirrel
Would be helpful if you divulged what vehicle (MY, Trim/Engine)
Generally, it sounds like you might have a fuel injector issue however the “steering wheel” light is a mystery and the stability control light is not related to the DTC’s.
A blinking CEL means stop the engine immediately. So is your V parked or already in the shop?
Old Apr 10, 2026 | 07:34 AM
Powerplant's Avatar
2012 CRV EXL 2.4L
It's parked, I've already replaced both 02 sensors (twice), both cats and the P0420 code remains. Replaced the MAF, I installed 4 new injectors but 2 of them started misfiring right off the bat so I don't know if I got 2 bad ones or if it was something with the car. I put the old ones back in and it went back to only 1 cylinder misfiring.
I've considered maybe it was a voltage issue as on other vehicles when the cluster lights up like a Christmas tree that's usually the problem. This weekend I'm installing a different alternator and another set of new injectors. I'm also going to do a compression test. I checked the valve adjustment and all is good there. I had swapped coils from my 2013 crv and that didn't change anything. Maybe a dirty fuel filter?
Old Apr 10, 2026 | 11:46 AM
Just Ducky's Avatar
Default Parts Cannon
Interesting. Normally I would ask if you are using knock off parts from Amazon, EBay or alike however since you replaced the O2 sensors and Cat and the P0420 remains I would think that your issue resides upstream.
Is Cyl 3 sparking?
Edit: Checking your fuel pressure would be a good way to check.
Jp028
Sep 10, 2023 09:54 PM
eddy1863
Apr 20, 2023 09:46 PM
skettibender
Jan 22, 2019 10:47 AM
Kirrog
Mar 4, 2017 10:16 AM
accoman
Feb 21, 2014 10:26 PM
