97 CRV problem
Old Jun 11, 2020 | 01:22 PM
ammo's Avatar
Default 97 CRV problem
The passenger front window will not go up or down. I have checked the window motor with direct power and it works fine. I have power to the door witch and the master switch. The door switch has a 5 wire plug and I have identified the two wires that go to the motor and the motor works fine. Neither the master switch or the door switch will work the passenger window. Both the master switch and the door switch have been changed. Problem still exist. All other windows work fine. Any ideas what to do next?
Old Jun 12, 2020 | 09:05 AM
The door switch has 5 wires
2 go to the motor power and ground depending up up or down
Then 1 wire has the power to switch which goes to motor
The other two come from the master switch. 1 for up and the other for down (providing the ground side)
If you checked the motor by putting power and ground directly to motor
Then you by-passed the two wires from switch to motor
That is the only thing that is for the front passenger window and not the other windows
So, would check to see if power and grounds get to the window motor when switch is activated
Also, check and clean connections. Corrosion will prevent current from flowing and not allow windows to work
drew and not u
Jun 25, 2023 11:13 PM
Dmil74
May 19, 2018 07:41 PM
saladfiend
Mar 11, 2011 07:28 AM
skifreak
Oct 18, 2010 04:09 PM
slilley92
Jun 28, 2008 11:27 PM
