Adding trans cooler for crv
Old Sep 4, 2024 | 11:25 AM
case310350's Avatar
Default Adding trans cooler for crv
Thinking about adding a transmission cooler to a 2017 honda crv. Currently facing torque converter shutter. TSB's indicated shutter is do to high fluid temperature degrading the fluid. 3x flush then change every 30k not 60k. So if high temps are the underlying issue one would thing a trans cooler would help. THOUGHTS ON THIS???
Old Sep 4, 2024 | 12:12 PM
What temps is the tranny getting to?
Old Sep 4, 2024 | 01:51 PM
Just Ducky's Avatar
Default Heat
Wondering why the high trans temps that would degrade the fluid?
If there is a TSB on this it is known but no recommendation for adding a cooler.
Usually coolers are fitted for heavy loads, commercial use and towing.
bobinyelm
Nov 30, 2023 08:46 AM
King
Feb 22, 2022 06:32 PM
jblaine
Jun 17, 2021 04:34 PM
Bsmith615
Feb 29, 2020 10:30 PM
Razorbacksfan88
Nov 17, 2006 10:53 PM
