Brake light issues
Brake light issues
Recently bought a '98 CR-V. Everything is in tip top shape but the brake lights don't work. Replaced brake pedal switch and bulbs to start with and no change. Tonight I broke out the multi-meter and checked for power at the driver side taillight connector. There's power in turn signals, running taillights but nothing from brake pedal when engaged. I'm pretty clueless what it could be at this point. Any suggestions?
Download the service manual at Archive.org
https://archive.org/details/HondaCRV19972000
Thanks for the welcome! When you say check the emergency switch, do you mean the the hazard lights switch? and the fuse for the hazard lights? My fuse block doesn't have a spot labeled for brake lights.
That is good news. Not an expensive fix and done right.
