Brake light issues
Old Apr 26, 2021 | 10:32 PM
AlpineBud's Avatar
Default Brake light issues
Recently bought a '98 CR-V. Everything is in tip top shape but the brake lights don't work. Replaced brake pedal switch and bulbs to start with and no change. Tonight I broke out the multi-meter and checked for power at the driver side taillight connector. There's power in turn signals, running taillights but nothing from brake pedal when engaged. I'm pretty clueless what it could be at this point. Any suggestions?
Old Apr 27, 2021 | 12:11 AM
welcome to the forum. check the emergency switch, i believe the brake power goes thru that. also check the fuse.
Old Apr 27, 2021 | 08:06 AM
Download the service manual at Archive.org
https://archive.org/details/HondaCRV19972000
Old Apr 27, 2021 | 09:48 AM
AlpineBud's Avatar
Thanks! This will help immensely.
Old Apr 27, 2021 | 09:49 AM
AlpineBud's Avatar
Thanks for the welcome! When you say check the emergency switch, do you mean the the hazard lights switch? and the fuse for the hazard lights? My fuse block doesn't have a spot labeled for brake lights.
Old Apr 29, 2021 | 12:33 AM
AlpineBud's Avatar
thanks for the help. turns out the manual was the best tool in diagnosing the problem. missed a fuse(15A) in the under hood fuse block cheers!
Old Apr 29, 2021 | 12:56 PM
That is good news. Not an expensive fix and done right.
skjlprince
Feb 13, 2020 12:15 PM
Jesse Tiznado
Dec 1, 2017 08:59 PM
tbg9910
Feb 22, 2016 06:54 PM
Ltt
Jun 10, 2009 03:39 AM
theokengineer
Jan 27, 2007 03:00 PM
