DIY help pls
Old Aug 19, 2018 | 02:29 PM
vern1's Avatar
Default DIY help pls
I have a coolant leak and after taking off the front cowl/shielding (what a pain, every clip broke off so have to buy new ones) i have tracked it to a hose that enters the thermostat housing from the water pump (i believe)
There is no way to get at this hose without taking out the radiator. Even then i dont know where the other end of the hose is attached and whether i can get at it without doing a lot of other parts removal
Has anyone done this and can provide some guidance? I dont want to pull the rad etc and then find out i have to pull 6 other parts off. If its a real PITA then i will just take it to my local wrench and get him to do it
Many thanks
Old Oct 30, 2018 | 03:40 PM
Lochinvar's Avatar
Default What year CR-V do you have?
Knowing the year of your car would help. What y'al is it?
Old Oct 30, 2018 | 04:08 PM
vern1's Avatar
Its a 2002 but i took care of this 6 weeks ago. Couldnt figure out where the leak originated so took it to my local wrench. Was leaking in 2 places
Thanks
ironknight
Jul 22, 2018 04:12 AM
Ceejherooftime
Mar 28, 2018 05:52 PM
sloweddi
Feb 3, 2015 07:47 PM
myshelly2010
Apr 21, 2013 01:39 PM
ajaybali
Apr 26, 2010 02:19 PM
