Entire Transmission Replacement or Just Speed Sensor?
Old Oct 8, 2024 | 10:34 AM
theyegis's Avatar
Default Entire Transmission Replacement or Just Speed Sensor?
Hi all,
I have a 2016 CR-V with 82K miles. I bought it used in 2021, with, to my knowledge, no prior transmission issues. My "D" gear light started blinking yesterday, in addition to the AWD and check engine lights turning on. Additionally, the gear changes feel very clunky and the car needs more pedal push to get moving. After doing a scan, I received code P0717, which, after following this thread, I learned likely means the torque converter turbine speed sensor needs to be replaced. I also received code C0077 which I suspect is unrelated, code 11-02 which I suspect has to do with battery dying earlier this year, and code C1871 which I suspect is the AWD turning off when the transmission issue arose. I have not changed the transmission fluid since getting the car - don't know for sure if anyone did before me, but I'm doubtful.
Now I'm not terribly confident about doing a replacement like this without first getting some professional advice, so I took it to the local (well-reviewed) AAMCO for a free diagnostic. The mechanic there told me that the tranny is shot and will need to be replaced with a re-built (superior) CVT to the tune of $5K.
Now I'm unsure how to proceed. Should I get a second opinion on this, or is there some way for me to tell whether it's just the speed sensor or a whole replacement? Would appreciate any guidance.
Old Oct 8, 2024 | 01:26 PM
Did they give you some kind of paper? I'd like to know what codes are in the system.
Old Oct 8, 2024 | 06:47 PM
theyegis's Avatar
They gave a paper, but no codes. I provided the codes I got at least above.
Old Oct 8, 2024 | 07:11 PM
The only current code for the tranny is the speed sensor? If there are no other P07xx codes just replaced the sensor.
mikeharg
Aug 30, 2023 05:42 PM
samuel_gatech
Nov 4, 2009 04:46 AM
hondaAutomatic
May 7, 2007 03:23 AM
chuck norris hx
Nov 30, 2006 10:24 AM
