Multiple Warning Lights + Code P0087
Old Oct 5, 2024 | 10:18 AM
MJDeLeon's Avatar
Unhappy Multiple Warning Lights + Code P0087
I have a 2016 Honda Crv EXL 2WD. This morning after driving my car for about 5 minutes the power steering light, tire pressure light, traction control, and check engine light came on. All lights are orange. The car struggles to start. I last had the oil and oil filter changed one month ago. I filled all the tires to 33 PSI this morning and tried to reset the tire pressure light however it does not turn off. I checked the gas cap and it is on properly. I ran an OB2 and come up with two P0087 codes, which tells me there is something going on with the fuel pressure. Would fuel pressure cause these lights to come on because when I look up multiple lights coming on I come up with it being an electrical issue. The battery is 2 years old.
Old Oct 5, 2024 | 01:34 PM
Just Ducky's Avatar
Default Coded
Your issues are unrelated. While you may have low fuel pressure at the rail, it would not relate to TPMS.
So in your last sentence you mention the battery. Are you planning on checking it?
Old Oct 6, 2024 | 03:36 AM
MJDeLeon's Avatar
Cleaned the battery terminals and that worked for the dash warning lights. The car was still struggling to start. OB2 sensor only had one P0087 code after cleaning the battery. I have a slow oil leak, and my boyfriend realized my oil was low so he filled it up, I took the car for a drive and didn't have any problems. After the drive I started the car a couple times, and it didn't struggle to start. Could the low oil be the cause of the low fuel pressure code? Not sure why the low oil light didn't come on.
Old Oct 6, 2024 | 01:58 PM
Just Ducky's Avatar
Default Second Verse, same as the first.
Low oil means that the level is at or below the add oil line on the dipstick.
No, low oil will not cause a low fuel rail pressure DTC.
Meanwhile, back at the ranch, you cleaned the battery terminals and thereby reset the computer. The results were positive so is there a possibility that you may eventually actually check or have the battery checked?
For clarity, checked means a load test, static voltage reading, SOH, SOC and maybe even DOD (DOC).
Henry VIII
Old Oct 6, 2024 | 06:50 PM
Are you sure your battery is good? Sounds like it may be on the edge.
Old Oct 8, 2024 | 02:15 AM
MJDeLeon's Avatar
Henry VIII
Yes, I'm going to have the battery checked this weekend.
Old Oct 8, 2024 | 02:17 AM
MJDeLeon's Avatar
I mean I just bought it 2 years ago, but I'm going to get it checked this weekend.
Old Oct 8, 2024 | 01:23 PM
Some batteries fail in under 2 years.
Old Oct 9, 2024 | 03:48 AM
MJDeLeon's Avatar
Oh so I wondering if the battery says 3 years on it, and it goes under that timeframe is it under warranty. I'm going to have to look into that. Thank you.
blumac81
Oct 27, 2023 09:20 AM
cgeorge2525
Jan 6, 2022 08:53 AM
Brenda B
Sep 22, 2019 10:29 AM
skettibender
Jan 22, 2019 10:47 AM
advait
May 24, 2013 08:51 AM
