Ground clearance
Old Jul 29, 2017 | 05:48 PM
Jerry Smith's Avatar
Default Ground clearance
Do 2WD CR-V's...any year...have any greater ground clearance than the AWD's do?...is the resonator able to be tucked up any higher due to no rear drive shaft on the 2WD's? Any other reasonable solution to this problem?
Would MUCH rather have a CR-V for a motorhome towable than a Jeep, but that huge resonator hanging down there reduces the AWD CR-V ground clearance down to not much more than my Buick Century, even on the 1st Generation CR-V's. Not looking for a rock crawler, just something with an AT that can be flat-towed and can handle some forest/desert roads without anything hanging down to catch on rocks, etc.
Old Jul 29, 2017 | 07:26 PM
Welcome in,the ground clearance on CRV's through 2016 is 6.7 inches and the new CRV is 8.2 considerable difference,as for the res,you might be able to get an aftermarket piece that is smaller,check into it.good luck.
mohsin_a
Dec 29, 2016 07:35 AM
RTChonda
Mar 15, 2010 11:26 AM
mrClen
Apr 16, 2007 12:05 AM
