HR-V wheels on 2009 Honda CR-V
Old Nov 15, 2019 | 09:54 PM
slidetbone's Avatar
Default HR-V wheels on 2009 Honda CR-V
I came across a set of Honda HR-V rims. The bolt pattern for the HR-V is the same as the CR-V. Offset and rim width for the HR-V is 7.5Jx17 ET55. The CR-V is 6.5Jx17 ET50. Will they fit the CR-V ok?
I assume the HR-V rims on the CR-V will stick out 5mm more, but the 1 inch rim width...will it matter?
Thanks!
Old Feb 19, 2020 | 03:07 AM
azitlies's Avatar
I'm not sure if a 2009 would be okay, but my 2014 (50mm offset also) worked fine with 7.5x17 ET55.
One thing about the wheel offset, if the offset increases, that means the wheel hub is farther out from the center of the wheel, resulting in the wheel sitting *farther in* the wheel well of the car. So instead of 5mm farther out, they'll be 5mm farther in. With the rim difference added in, there's the chance the rim will hit brakes parts. Mine didn't, but I'd say the only way to know for sure is to mount one of the rims and see.
Cheers
tanjid111
May 7, 2018 02:36 PM
Dieselgal73
Feb 21, 2017 08:15 PM
NBill
May 5, 2014 01:55 PM
emgfn
Mar 28, 2014 05:27 PM
Donkeydawn11
Jul 2, 2010 10:01 PM
