Intermittent Juddering on Acceleration
Old Aug 4, 2020 | 12:00 PM
SanjitBansal's Avatar
Default Intermittent Juddering on Acceleration
I have a 1999 Honda CRV, 2.0 petrol with a manual gearbox.
Sometimes when I start the car the engine management light is on and the Rev counter doesn't work. When I accelerate the car judders until I change gear.
Also, sometimes I start the car and there is no engine management light and the Rev counter is working, the car runs fine.
I've changed the spark plugs, leads and air filter and it hasn't made any difference.
The only other thing I noticed today is that the car was running fine, I stepped out for 2 minutes and left it running...it then just turned off on its own. When I restarted it the engine management light was back on.
Any ideas what could be wrong?
Old Aug 4, 2020 | 08:31 PM
welcome to the forum few ideas. brake rotors, bent axels, tye rod ends/bushings, alignment, eng mount worn, worn cv's
Old Aug 5, 2020 | 12:26 PM
First scan or read the codes in the ECU pending and permanent
M_Gray35
Nov 6, 2018 06:49 PM
BrittneyLee
Aug 24, 2015 07:24 AM
Drwaffles
May 1, 2013 03:00 PM
christina1385
Feb 3, 2011 09:31 PM
