Maintenance Specs
Old Feb 11, 2021 | 10:00 AM
Steelhmr's Avatar
Default Maintenance Specs
Just picked up a 2015 CRV EX. Does anyone know the following maintenance specs?
- Lug nut torque
- Engine oil
- Oil Filter part #
- Oil drain plug crush washer part #
- Oil drain plug torque
- Cabin Air Filter part #
- Engine Air Filter part #
- Brake Fluid
Thanks!
Old Feb 11, 2021 | 12:43 PM
ST13Fred's Avatar
Go to any Honda parts website where you can look up a part from their micro fiche. I've had good luck on pricing with Bernardi parts.com on Honda accessories.
I use a 17mm box wrench (12" long?) to tighten drain plug; crush washer can be used again; Castrol/Mobil 1 have the full synthetic oil; use only Honda brake fluid.
As for torquing with the box tighten down to snug then give at short quick pull, not too hard not too soft. Same with lug nuts. Look up standard torques if uncomfortable with this technique. Good luck.
Old Feb 12, 2021 | 11:02 AM
Steelhmr's Avatar
Thanks Fred, I will check it out.
Old Feb 13, 2021 | 08:46 AM
Welcome in,this info should be in your owners manual
Old Feb 13, 2021 | 11:49 AM
- Lug nut torque
- Engine oil
- Oil Filter part #
- Brake Fluid
Thanks!
Call up a Honda dealership near you.
They will have it on their computer screen in less than two minutes
They can also give you price and availability
Scott in FL
May 13, 2024 12:55 PM
Marc
Dec 6, 2012 10:18 PM
Heatdepot
Jul 27, 2010 09:41 PM
henyawill
Nov 18, 2008 06:29 AM
Khonsaiho
Jul 18, 2007 06:49 PM
