Rust in rear doors
Old Jan 8, 2019 | 04:28 AM
Allan Ankjær Klausen's Avatar
Default Rust in rear doors
Im a very happy CR-V owner since 2014. I have done 103000 troublefree km`s and all is fine except I just found somre nasty rust in both rear doors. Anyone with similar problem? Its a 2014 1,6 diesel
Old Jan 8, 2019 | 06:25 PM
welcome to the forum. I don't have a cr-v, but if you are under the 5 year warranty for Honda, rust is one of them. you might check to see if Honda will fix this. also check to see if the rear door bottom drain slots are open and clear/clean. you may want to open the door panels to see how bad the damage may be. if Honda does not warranty the rust coverage, you can sand down the rust with wire brush, and spray the rust area's with lps 3. wd-40 will wash away too quick.
Alex Lewis
Dec 7, 2021 12:21 PM
vad
Oct 30, 2016 04:18 PM
grakowsky
Aug 13, 2015 03:10 PM
Chap Capuyan
Nov 5, 2013 06:54 PM
