Starter or Alternator or Something else,
Old Sep 19, 2024 | 08:44 AM
udsxvp's Avatar
Default Starter or Alternator or Something else,
Wife has a 17 CRV and it's been having intermittent starting issues. Sometimes it wont start and click, sometimes it hesitates to start, sometimes starts with no issues. Battery is fine it's been tested. Starter tested fine at Auto zone but I am figuring if the issue doesn't happen while testing it wont read anything. I was thinking starter but one odd thing is that the hatch won't open by pushing the hatch button on the hatch or from the key fob until the car starts. The low battery on the fob isn't coming on the dash like when the key fob is dying. Now that I am typing this I am wondering if the Battery in the fob is weak and not getting a good signal?
Anyone of the mechanics or gurus out there have ideas?
Old Sep 19, 2024 | 02:29 PM
Let's work on the no start. I would start by looking at the relay. You mention a click.
Old Sep 19, 2024 | 02:49 PM
udsxvp's Avatar
Yes sometimes it wont do anything but click. others it will start just hesitated. and other times starts fine
Old Sep 20, 2024 | 06:23 AM
Bubbalou88's Avatar
I have had Autozone test battery and say it was good and the same symptoms as yours I used a voltmeter to see if alternator was putting out the correct voltage ( it was ) so I told them to change the battery anyway and problem solved. If no voltmeter you need them to check the alternator and if ok, change the battery
Old Sep 20, 2024 | 08:44 AM
When the relay clicks only I would swap it with another and see what you get.
Old Sep 20, 2024 | 10:00 AM
udsxvp's Avatar
I had the battery tested and it tests fine at 100%
Old Sep 20, 2024 | 12:57 PM
Load tested? What were the numbers?
Old Sep 20, 2024 | 12:58 PM
udsxvp's Avatar
They didn't give me the #s just said it was at 100%
Old Sep 20, 2024 | 05:55 PM
Who is they.
Imisskeys
Mar 25, 2024 12:30 AM
aerovette99
Sep 12, 2023 07:10 AM
stateship2
Nov 22, 2018 08:15 AM
bozobeebutler
Dec 26, 2016 07:52 PM
SOKal
Nov 14, 2006 12:41 AM
