Wheel fitment
Old Feb 10, 2020 | 12:17 PM
Rustyfocker's Avatar
Default Wheel fitment
Will 2017 Subaru Outback wheels and tires (225/60/18) fit a 1999 crv? I believe lug pattern is same just not sure of offsets and backspaceing and if 18 will clear. any help appreciated.
thanks.
Old Feb 11, 2020 | 01:11 AM
welcome to the forum. according to tire rack, the tire 22/60/18 should fit the 99 cr-v, the rim for the 17 subaru bolt pattern is 5x114,3 mm. vs crv bolt pattern is 5x115mm. bolt pattern seems close to the eye, but a little off.
Old Feb 11, 2020 | 12:49 PM
thanks for your reply ,
everything I read says they are the same bolt pattern 114.3
Old Feb 12, 2020 | 09:42 AM
VehicleNanny's Avatar
If you get a chance to test fit them first, do it. I bought rims for a Jeep Liberty that had the specs to fit, but when I did test fit the spokes of the wheel rubbed the brake caliper. I probably could have shaved the edge of the caliper a bit, but did not want to risk messing with the structural integrity of the caliper.
slidetbone
Feb 19, 2020 03:07 AM
Finch Platte
Jan 1, 2019 11:21 AM
tanjid111
May 7, 2018 02:36 PM
Fap17
Sep 23, 2009 07:00 AM
miniguy
Feb 3, 2007 04:07 PM
