Cruising / Standard Valkyrie, VTX, Shadow, Nighthawk, and Rebel related information.
78 Hawk CB400 advice
Old Jun 15, 2007 | 04:25 PM
toohey's Avatar
Default 78 Hawk CB400 advice
I'm a new motorcycle owner and my bike won't start!! I cleaned gas out of the air filter, changed spark plugs, gas and battery and can't get it to start even though it is turning over. Any advice from someone with experience in this matter?!? Please let me know, I want to ride!
Old Aug 31, 2007 | 02:49 AM
lazzer408's Avatar
Default RE: 78 Hawk CB400 advice
Give it a shot of Gumout carb cleaner down the carbs and see if it'll run off that. Carefull for backfires because it'll light the cleaner so dont soak the hell out of it. 1 second spray down each carb is more then enough to see if it'll fire up. If not, you have an ignition problem (or some major mechanical failure). If it starts then dies you have a fuel/carb problem. Remember, the choke only works with the throttle CLOSED on most motorcycles unless it uses a butterfly type choke. Good luck
SpunkyFunky
Aug 7, 2012 03:53 PM
lazzer408
Aug 31, 2007 02:14 AM
samuel
Dec 13, 2006 08:04 PM
bkmass
Dec 5, 2006 01:44 AM
redintex
Nov 27, 2006 08:21 AM
