Element Forum This unique crossover provides the interior room of a minivan with the abilities of a compact SUV.
cluster illumination issue
Old May 6, 2023 | 12:14 PM
Wood.Sharpening's Avatar
Default cluster illumination issue
hi all,
just wanted to share my fix to a known issue on the element,
the issue is of the cluster illumination going out, to which some have suggested a whack on top of the dashboard, which works for some, others have suggested the more involved procedure of wedging stuff in the (larger) green connector found behind the clustercluster.
the owner of the element i worked on had done both with success but unfortunately the luck had run out.
in my experience, the green connector is the culprit. my fix is to give a slight bend to the pin on the female connector (the one on the cluster itself) in order to force a better contact.
the pin is the one matching the (all) red wire on the pigtail, which is the bottom row, second one from passenger side (when the cluster is mounted).
​​​​for what its worth.
EricE85
Oct 26, 2020 11:27 AM
Jiggymatt
Jun 23, 2016 07:39 PM
Chris Crumley
Mar 29, 2016 10:09 PM
sia_simba
Apr 27, 2007 12:01 AM
