95 Honda carb question
Old Jan 13, 2010 | 09:06 AM
dgalati000's Avatar
Default 95 Honda carb question
What is the diff between an EFI and MPI in the engine specs ??
Old Jan 21, 2010 | 01:20 AM
welcome to the forum. This a quote from redrepair in Yahoo. "There are many ways to look at injection systems EFI,MPI,MFI. Electronic Fuel Injection is the type of system. Main systems are EFT or MFI (electrical or mechanical). MPI is a sub system description of the first. So you now have a choice of Single Port Injection or Multiport Injection. Most SPI are nothing more than a Carburetor body/or valve body that has been adapted to accept a single injector feeding all the cylinders. Multiport breaks down into two classifications - direct or indirect. In a Direct system the fuel is being supplied directly to the combustion chamber why Indirect it is being supplied to the intake manifold(s) or precombustion chamber (diesels), From there you can have single or multiple injectors feeding one combustion chamber. So in theory you can have a Electronic single multiport direct fuel injiction, Mechanical dual multiport indirect fuel injection, Electronic single port indirect fuel injection, or about a combnatiions depending on how many intake manifolds, how many injectors, and how many injectors per cylinders."
Old Jan 21, 2010 | 09:52 AM
dgalati000's Avatar
Default VTEC vs non VTEC engine in 97 Accord
Hi, are the VTEC engines "better" than the non VTEC engines? Maintenance wise...
james9120
Aug 30, 2010 01:51 PM
sparkmaster123
May 12, 2009 09:10 PM
splat41
Aug 27, 2008 09:21 PM
samepotential
Dec 9, 2007 06:13 PM
igotbagd
Oct 24, 2005 03:41 PM
