v tec wiring harness
Old 03-22-2008 | 01:05 AM
cturl69's Avatar
Default v tec wiring harness
i was lookin to buy a 1995 civic with a mini me swap in it and i was wondering if anyone has ever heard of the car not running bc there was not a vtec wiring harness. thouhg the guy said that i could pin the non vtec wiring harness to the ecu. how hard would that be to do?
Old 03-27-2008 | 02:58 PM
94D16Z6's Avatar
Default RE: v tec wiring harness
a friend of mine did the mini-me swap a couple months back, and he didnt have any troubles with not starting, his v tec still is not hooked up...check into it before u buy...
Old 03-27-2008 | 03:06 PM
cturl69's Avatar
yea i am thinkin he has screwed somethin up, thanks for the advice
Old 07-15-2009 | 05:24 PM
rsmckee's Avatar
yea man its not the vtec not wired up check your fuses but to wire the vtec its not to hard its only a cople of wires and a cople of pin connecters from radioshack there are diagrams all over the internet depending on the ecu you have!
Old 03-01-2014 | 10:54 PM
Gator417's Avatar
^^^ Definitely true. Could be a siezed bearing or just a connector loose.Check the codes. A car will tell you alot about itself if you just take a few minutes and listen. It wants to run. Running is its natural place, its home. Help it go home.
Gator
TimHays
07-04-2013 05:25 PM
Hoodie951
04-09-2010 11:14 PM
jrandall12845
05-28-2009 04:59 PM
jerij
08-13-2007 10:29 PM
BONEZ600RR
11-18-2006 03:37 AM
