09 civic startup
Old Mar 9, 2022 | 08:11 AM
jptate71's Avatar
Default 09 civic startup
After the 09 civic has been sitting for several hours i have to hold they key in start position for about a minute (climbed from 30 seconds over the last 2 months). All of the lights fans etc come on when i turn the key and It starts up immediately once the starter turns. I replace fuses/relays associated with startup. Also replaced the keys & ignition barrel & switch. Im wondering if the battery is right at a level to cause this or the starter solenoid
Old Mar 10, 2022 | 07:02 AM
Well, it sounds like the starter motor is beginning to fail. No way to be sure until it does. When it does, sometimes hitting a starter will let it start the engine, one last time. But, yes, check the battery voltage and load test.
JR66
Jul 5, 2020 11:24 PM
stateship2
Nov 22, 2018 08:15 AM
mrsalesco46
Aug 6, 2010 05:46 AM
honda114
Jul 4, 2009 07:30 PM
SOKal
Nov 14, 2006 12:41 AM
