1996-97 Accord front rotor & hub
Have you succeeded removing the hub assembly since your last post?
I'm currentlyreplacing the front rotor & brakesof my brother-in-law's 1997 Accord. So far, it has been very frustrating due to the poor design of the braking system. I'll post the process when I'm done.
KT
KT
I have a 91 accord and if it's the same design, it's a poor one in my opinion. I have a shop press, so it wasn't all that bad of a job,because thebearings have to be sacrificed in order to press the hub out of the bearing. I took digital pics of the process. Let me know if you're interested.
Yeah I have and it does suck.You will need a new wheel bearing.just take the knuckle/hub assembly off the vehicle then remove the 4 bolts in the front and the 4 bolts on the backside. Then get a bigass hammer and beat the **** out of the back rotor.It takes alot of beating to get the wheel bearing to come apart.You might even need a press if the wheel bearing comes apart.
Suze
Oct 17, 2007 02:24 PM
