1996-97 Accord front rotor & hub
Old May 7, 2006 | 05:03 PM
davidLX's Avatar
Default 1996-97 Accord front rotor & hub
Has anybody successfully replaced front rotors on a 1996 or 1997 Accord. If so, how did you detach the hub assembly?
Old Jun 29, 2006 | 01:54 PM
nonewsisgoodnews's Avatar
Default RE: 1996-97 Accord front rotor & hub
Have you succeeded removing the hub assembly since your last post?
I'm currentlyreplacing the front rotor & brakesof my brother-in-law's 1997 Accord. So far, it has been very frustrating due to the poor design of the braking system. I'll post the process when I'm done.
KT
Old Aug 7, 2006 | 02:07 PM
jjr_exr's Avatar
I have a 91 accord and if it's the same design, it's a poor one in my opinion. I have a shop press, so it wasn't all that bad of a job,because thebearings have to be sacrificed in order to press the hub out of the bearing. I took digital pics of the process. Let me know if you're interested.
Old Nov 30, 2006 | 06:11 PM
Benniehonda's Avatar
Yeah I have and it does suck.You will need a new wheel bearing.just take the knuckle/hub assembly off the vehicle then remove the 4 bolts in the front and the 4 bolts on the backside. Then get a bigass hammer and beat the **** out of the back rotor.It takes alot of beating to get the wheel bearing to come apart.You might even need a press if the wheel bearing comes apart.
robertc0087
May 3, 2013 10:27 AM
suzy fisher
Dec 1, 2008 06:28 PM
Suze
Oct 17, 2007 02:24 PM
JJ98
Sep 15, 2006 11:24 AM
davidLX
May 8, 2006 12:27 AM
