2001 Honda AC fan not blowing
All of the lights are functioning as normal, but no fan when I adjust the fan speed with the climate control dial.
I can turn the AC on and off as well as set the air to circulate in the cabin, but the fan will not turn on (the 3 lower horizontal buttons).
I took it to a shop initially and they told me the climate control unit needed to be replace, so I purchased a used replacement.
When I installed it, I had the same results.
So either something else is wrong OR the replacement unit is also bad.
I am by no means a mechanic, but would like to know if anyone else has a suggestion on what might be wrong before I take it in and spend $400 to fix it.
Thanks!
Thanks!
shad9876
09-03-2008 12:57 PM
