2001 Honda AC fan not blowing
Old Apr 7, 2013 | 05:40 PM
jazzinm's Avatar
Default 2001 Honda AC fan not blowing
All of the lights are functioning as normal, but no fan when I adjust the fan speed with the climate control dial.
I can turn the AC on and off as well as set the air to circulate in the cabin, but the fan will not turn on (the 3 lower horizontal buttons).
I took it to a shop initially and they told me the climate control unit needed to be replace, so I purchased a used replacement.
When I installed it, I had the same results.
So either something else is wrong OR the replacement unit is also bad.
I am by no means a mechanic, but would like to know if anyone else has a suggestion on what might be wrong before I take it in and spend $400 to fix it.
Thanks!
Old Apr 7, 2013 | 07:40 PM
lowlife9's Avatar
could be the blower moter itself could be just a blown fuse or maybe even a blockage in the fan. check the filter see if theres a rodent nest in there it happened to me before.
Ottoa59
Feb 15, 2012 07:53 AM
aiden_arvien
Jan 13, 2010 04:25 AM
palomino
Sep 28, 2009 09:34 PM
shad9876
Sep 3, 2008 12:57 PM
stevel
Jun 28, 2008 09:48 AM
