2006 accord acting up
Old 08-14-2011 | 07:31 PM
tompav's Avatar
Angry 2006 accord acting up
I have a 2006 accord coupe with 135,000 miles on it, and once in a while when i start the car, the RPM only hits .500 then stutters and stalls. I give the car a minute till i start it again, and it starts up strong. Sometimes it takes more than once till the car starts up strong. And this really only happens once in a blue moon, so its a little frustrating cause i don"t have a constant problem to really understand whats going wrong. I replaced the battery, and checked the voltage and it was 14.0 volts, which is normal. Does anyone know of something that could be the problem? I am assuming the alternator is fine if the car does not die out while i am driving it. If anyone knows of something, i would appreciate it.
Old 08-17-2011 | 09:13 AM
Welcome to the forum,sounds like the injectors are leaking down over night.
Old 09-04-2011 | 12:29 AM
ianclarkson55's Avatar
Have you checked out injectors? they may be the real problem as the member above me pointed out.
Old 09-19-2011 | 10:47 AM
Tom,did you find out what the problem was?
Old 10-05-2011 | 05:39 AM
lowlife9's Avatar
do you let the fuel pump fully prime before you start the car ??
Old 10-31-2011 | 07:20 AM
Derek_Miller's Avatar
Check the injectors. Plus 135k is a lot when was the last time your car got a tune up?
Old 11-01-2011 | 03:00 AM
smith_cody's Avatar
i think it is the battery prolem once again check it if it is not ythe problem check the injectors.
Old 11-15-2011 | 08:28 AM
You should try disconnecting the radio fuse and check the epr ports again.
jonathangoff
06-22-2010 11:28 AM
1990b16hatch
11-19-2008 12:25 PM
silverbullet
01-22-2007 03:21 AM
Pak996
09-23-2006 06:15 AM
Cindaro
08-18-2006 07:36 PM
