2010 Honda Fit Electrical Issue with Passenger Headlight/Running Light/Blinkers
Old Oct 29, 2019 | 04:33 PM
wavy4jc's Avatar
Default 2010 Honda Fit Electrical Issue with Passenger Headlight/Running Light/Blinkers
Hello, just had a weird situation happen with my front passenger side headlight/daylight/parking light/blinker. They ALL lights stopped working at the same time. ALL bulbs work (I put them in the drivers side sockets to check). The front right blinker (passenger side) blinks very fast (The drivers side blinker is normal). The rear passenger side blinker light DOES work and it blinks very fast also. There is NO power coming to the front passenger side light bulb sockets. I Could not find a fuse to correspond to any of the front passenger side lights. I assume that the blinker relay works because the drivers side blinker works fine.
Has anyone else has this issue happen to them? I would appreciate any help or advice that you could share. Thanks so much!!
Old Oct 29, 2019 | 09:17 PM
Take a look at where the ground side wires go
It may be a ground issue. Rust corrosion.
Bad ground??
Old Oct 30, 2019 | 08:29 AM
wavy4jc's Avatar
Bad ground??
Any idea as to where the ground wire might be? I did a quick check (due to limited time I had this morning) and saw no visible or obvious ground wire for ALL three passenger lights (Headlight/blinker/parking light.
Old Oct 30, 2019 | 04:35 PM
have you checked the fuses under the hood (drivers side) and on the left side of the drivers knee area (interior). has there ever been and accident on the right side of the car that may have damaged wires. when you took the wires off the back of the light bulbs, trace the lines back to see if any have damage or disconnected.
theoriginalmartian
Jun 18, 2018 09:10 PM
xplicitelem3nt
Apr 6, 2009 06:35 PM
david_leru
Jan 6, 2007 04:52 PM
