2013 Pilot windshield washer hose leak
Old Mar 29, 2023 | 10:42 PM
Ronvb's Avatar
Default 2013 Pilot windshield washer hose leak
Hi all
I have a leak in the washer hose that runs to the rear assembly on my 2013 Pilot. I suspect mice since I found a nest in inner fender well on front passenger side. It leaks close to the firewall underneath to the ground.
My question is : How can I access the hose to replace or patch it? I tried removing inner fender well but still cant get to hose leading away from pump. Do I have to pull interior sill plate and other panels to get to it?
thanks
Old Mar 30, 2023 | 09:27 AM
Does it leak even when not using the washer?
Old Mar 30, 2023 | 09:36 AM
Ronvb's Avatar
It only leaks when I top off fluid or if I hit button for rear washer
Old Apr 5, 2023 | 06:44 AM
Ronvb's Avatar
Anyone have diagram how lines run to the back?
Old Apr 5, 2023 | 09:02 AM
I would think they run along the frame channel to the trunk.
SCJax
Jan 23, 2022 04:38 PM
vern1
Oct 30, 2018 04:08 PM
ajaybali
Apr 26, 2010 02:19 PM
ashemorris
Apr 9, 2010 08:18 PM
omer61
Jun 10, 2007 05:39 AM
