2013 Pilot windshield washer hose leak
Old 03-29-2023, 10:42 PM
Ronvb's Avatar
Default 2013 Pilot windshield washer hose leak
Hi all
I have a leak in the washer hose that runs to the rear assembly on my 2013 Pilot. I suspect mice since I found a nest in inner fender well on front passenger side. It leaks close to the firewall underneath to the ground.
My question is : How can I access the hose to replace or patch it? I tried removing inner fender well but still cant get to hose leading away from pump. Do I have to pull interior sill plate and other panels to get to it?
thanks
Old 03-30-2023, 09:27 AM
Does it leak even when not using the washer?
Old 03-30-2023, 09:36 AM
Ronvb's Avatar
It only leaks when I top off fluid or if I hit button for rear washer
Old 04-05-2023, 06:44 AM
Ronvb's Avatar
Anyone have diagram how lines run to the back?
Old 04-05-2023, 09:02 AM
I would think they run along the frame channel to the trunk.
SCJax
01-23-2022 04:38 PM
vern1
10-30-2018 04:08 PM
ajaybali
04-26-2010 02:19 PM
ashemorris
04-09-2010 08:18 PM
omer61
06-10-2007 05:39 AM
Quick Reply: 2013 Pilot windshield washer hose leak
