2014 Crosstour starting problem
Old Mar 26, 2022 | 01:59 PM
ER3idy's Avatar
Default 2014 Crosstour starting problem
I have a 2014 Honda Crosstour 4WD EXL V6 with 105,000 miles. At about 80,000 miles I would have an occasional problem starting. I would step on the brake and push starter button and it would fail. If I waited a minute and did it again it would start right up. This would happen once every 2 or 3 weeks and then start right up. My mechanic, who I trust, thought I should replace the ignition which I did at 90,000 miles . The issue continues every few weeks. It seems like the issue has something to do with some connection not being made when I step on the brake. Love the car but this issue makes me crazy.
Old Mar 26, 2022 | 06:47 PM
Relay?
Old Mar 27, 2022 | 12:57 AM
Guessing should check the brake switch to see if it is functioning
Personally, would clean battery posts and cable terminals with a wire brush to eliminate corrosion as a possible cause.
Old Mar 27, 2022 | 09:04 AM
ER3idy's Avatar
Sorry, what is a bark switch?
Old Mar 27, 2022 | 04:31 PM
Start button.
Old Mar 28, 2022 | 01:48 AM
Sorry, I meant brake switch. You might find the switch is faulty??
Cam and crank sensors are next suspects.
Do a visual inspection of wiring
Sometime you might catch a problem with the wiring??
Old Mar 28, 2022 | 07:49 AM
ER3idy's Avatar
Ok, thank you.
jpk_504
Aug 4, 2022 04:02 PM
BradW
Mar 26, 2022 07:25 AM
slmilde
Mar 10, 2020 11:54 PM
Vic Dennison
Dec 4, 2019 01:11 AM
tlabranche
Jul 8, 2018 06:40 PM
