2016 Pilot AWD differtinal fluid fill
Old 10-28-2018 | 06:23 PM
Ken2016's Avatar
Default 2016 Pilot AWD differtinal fluid fill
Just drained and refilled my diff and I put in 2 quarts and ~8 oz. Manual says it should be 1.9ish quarts. Can you overfill? I filled to about 1.8, started the engine, put in dirve for 10 set and spun the tires, then stopped wheels and put in reverse and spun the wheels ~ 10 seconds, then back in drive for 10 sec., finally put in park and continue to run engine for ~20 sec. NO spill or overflow. Topped up fluid until it just started to flow out the fill whole,,, wiped everything up and reinstalled the fill plug.
Ken
Old 10-29-2018 | 01:47 AM
welcome to the forum. as long as you filled it as per manual you should be good to go. also using proper fluid per manual. keep up the good work.
444samc
12-01-2019 08:11 PM
TgenIndy
09-02-2019 03:34 AM
sparesky
11-01-2017 05:45 PM
Rustyb
07-28-2011 01:22 AM
fjpthree
05-06-2010 07:34 AM
