ABS on a CRV
Old Jan 1, 2007 | 04:37 AM
proff's Avatar
Default ABS on a CRV
When braking hard the wheels lock up, This tells me the ABS isn't working.[:-]
I have no ABS dash light on.
I have no manual and I can not see a server unit or wheel sensors
The car is a 1997 CRV
Does this CRV really have ABS at all? cause I can't see any ABS componants at all
How does the ABS work on this car?
Where are the wheel sensors?
where do i start looking for problems?
If in Australia you can call me on 0412119530[:@]
Old Jan 6, 2007 | 06:30 PM
kornfox's Avatar
Member
Default RE: ABS on a CRV
I'm not sure if your vehicle is equipped with ABS or not. Especially if you purchased it overseas (Im in the US). If you do there can be a simple explaination. Your ABS dash light could be burned out. They best way to check is to get in the vehicle and turn your key to the "ON" or "ACCESSORY" position. This should run a quick diagnostic on all your dash lights. If you do not see and ABS light, your vehicle may not be equipped, the bulb could be burned out, or a fuse for the ABS system may be blown.Check it out and get back to me. Good luck.
Old Feb 12, 2007 | 01:00 AM
golfer's Avatar
The 97 did not come standard with ABS.
nikes_ny
May 20, 2007 02:29 AM
nikes_ny
May 2, 2007 12:58 AM
nikes_ny
May 1, 2007 12:59 AM
DadDog83
Nov 26, 2006 09:53 PM
