Accord 95 wont stay on
Old Jun 18, 2014 | 10:18 AM
Coreytreat's Avatar
Default Accord 95 wont stay on
Okay so heres some background...
Over a month ago it started acting funny, I would start my car and it would shut off after about a second. I would try starting it again and it would start right up. It started getting worse and worse it would happen more often or it wouldnt start right up the second time...it started taking 5-10 times to start. Finally about a month ago it just wont stay started at all. All it will do is run for a second and shut off.
I am getting a code 15. I replaced the whole dissy, the main relay, and checked ground 101. I have been talking to someone on JustAnswer for the last month and we have tested everything... Here is our conversation.
http://www.justanswer.com/honda/8hcz...ln=b1_viewr_bu
Any other ideas guys?
Old Jun 18, 2014 | 03:40 PM
lowlife9's Avatar
spark,air,fuel follow those and you should find the problem.are you getting proper fuel pressure are your spark plugs worn is your distributor functioning properly are your wires good.how are your oxygen sensors, mass air flow, air filter. have you tried a fuel system cleaner like Seafoam.is your battery charging properly. im guessing its a bad fuel pump.
Timmo3
Dec 31, 2013 10:34 AM
raychill
Aug 29, 2013 02:31 PM
89hondacrx
Jan 27, 2012 10:58 AM
onetwo12
Oct 6, 2009 04:36 PM
thedaveman89
Nov 24, 2008 09:32 PM
