Compression
Old Nov 5, 2008 | 11:34 AM
kan's Avatar
kan
Default Compression
Hello, HF Members.
I have a 98 hatch with type r b18c5 turbo. I had new low compression pistons and rings. The head is stock. I bolt the them together with new head gasket and arp bolts. Here is the problem when I bolt back the the camshaft then the engine got no compression. Looks like all the air leak through the Ehaust valves. I took the Exhaust camshaft out and there's compression. What could it be the problems?
Old Nov 6, 2008 | 07:16 AM
Default RE: Compression
welcome to the forum, with your head off and there is no leak through the valves with a fluid leak check. bolting the cam in place, the timing if not correct. at top dead center the lower surface of the cam should be over the valve to close the valve, check the timing of the cam with the manual to see if the cam is set correctly.all valves should be closed at top dead center.
this_25
Aug 10, 2009 07:46 AM
jonesdesign
May 27, 2009 10:24 PM
infrantry
Mar 30, 2008 05:22 PM
mickeyp
Dec 5, 2007 03:45 AM
rob11059
Oct 5, 2006 01:57 AM
