Did you replace the TIMING BELT??
Old Sep 25, 2007 | 10:51 AM
JimMayor007's Avatar
Default Did you replace the TIMING BELT??
I worked as a mechanic for many years. Honda and Acura vehicles use a rubber timing belt to keep the camshafts running correctly with the engine. These cars will run for 300,000 miles easily if kept maintained. The problem is the timing belt wears out. Honda/Acura recommend changing the timing belts every 90,000 miles. Normally the belt is under $40 by itself and labor is a few hours. You would be looking at a $300 bill to change the belt, before it breaks, as a scheduled maintenance item.
The problem is when people don't change the belt. After all, the car runs, why spend money on a car that isn't broken? But wait. If the belt breaks while the engine is running, the engine's parts go out of sequence. The pistons will actually hit the valves, causing expensive internal engine damage. It is not uncommon to find the cylinder head has to be rebuilt due to bent valves. Sometimes cracked pistons need replaced, meaning a whole new rebuilt motor. What would have been a $300 maintenance job is now a $2000 engine rebuild.
Why is this important? When buying a used Honda or Acura with over 100,000 miles, the first question asked should be, when was the timing belt changed? Do you have receipts? If the owner can't prove the belt was changed recently, if you decide to by the car, be aware you will need to get the belt changed as soon as possible to prevent ruining the engine.
...read the full guide with pics here
hondan1997
Jun 18, 2014 07:29 PM
chrisearl092
Nov 15, 2011 08:46 AM
209xintegra
Dec 9, 2009 02:24 PM
gregf
Apr 9, 2008 11:00 PM
rookie60
Jan 21, 2008 04:35 PM
