engine compression
Old Mar 28, 2008 | 05:18 AM
infrantry's Avatar
Default engine compression
i have a 93 honda accord and i was testing the piston compression and in piston 1 it said it was 90 psi on 2 it said 85 psi in 3 it said 90 psi and in 4 it said 90 psi. Anyone know why number 2 is at 85? Some people say that it might be a bent valve. Could that be it or could it be worn piston rings or something like that.
Old Mar 29, 2008 | 04:12 AM
Default RE: engine compression
It can be one of the following, carbon on either valves, weak compression rings, sticking valves, rocker adjustment to tight (keeping valve open slightly) If you do acompressed air leak check, you can hear if the air is coming from the intake, exhaust, or into the crank case.
Old Mar 29, 2008 | 10:12 AM
infrantry's Avatar
right now the car sound like a harley motorcycle when idleling. It makes a brup brup brup sound.
Old Mar 30, 2008 | 05:22 PM
When was your last tune up, plugs, wires, etc? Does it lope at higher rpm"sor smooth out, If you disconnect your battery cable for a shot time and rehook it up, and drive down to a parts shop that has an obd tester, they may find out what is going on with the engine.Call first to see if it is done for free.Some parts places do this as a service to find codes.
this_25
Aug 10, 2009 07:46 AM
jonesdesign
May 27, 2009 10:24 PM
kan
Nov 6, 2008 07:16 AM
mickeyp
Dec 5, 2007 03:45 AM
rob11059
Oct 5, 2006 01:57 AM
