Faulty Distributor
Old Jun 19, 2006 | 10:37 AM
Ricardo's Avatar
Default Faulty Distributor
Can anyone advise if a TD31U 1990 Accord distributor be serviced. My accord has power to the distributor but does not deliver a spark.
Is there a common fault with these units please?
Regards
Ricardo
Old Dec 5, 2006 | 10:59 PM
Benniehonda's Avatar
Default RE: Faulty Distributor
Take you distributor cap off (3 8mm bolts)Inspect the rotor for any hot spots or holes also check the contacts inside the distributor cap make sure there not damaged.If thats okay check the coil.If thats okay u need to check the ICM (ignitoin control module) I've seen those go bad but not to often a coil can usually fix the problem.
knto001
Apr 15, 2022 10:25 AM
hiddenramza
Jun 19, 2021 03:33 PM
Ostravaczech
Jun 22, 2013 09:43 PM
pidrowan
Feb 18, 2011 02:31 AM
donkeysnout
Apr 12, 2007 08:32 AM
