Having trouble with my radio.
Old Dec 12, 2011 | 03:00 AM
  #11
lowlife9's Avatar
there are to many variables to give you an answer your just going to have to go threw the entire setup to eliminate them.
Old Dec 12, 2011 | 09:11 AM
  #12
Originally Posted by lowlife9
having a aftermarket system you failed to mention that can absolutely be the culprit like external amplifiers and component crossovers just to name a few not to mention the wiring that was done could have been half assed. what do you have done exactly ???
I agree ,the next step should be the Amp. it may be bad,I had one in a home system go out and nothing will work when that happens.
Old Dec 13, 2011 | 12:22 AM
  #13
Cinder405's Avatar
The amp is brand bew. So are the speakers. All fuses are fine. Wiring was checked by the guy. And everything is fine. Its just now i have no sound. But ill just have to take to some pros to really get the problem fixed.
Old Dec 13, 2011 | 07:26 AM
  #14
Yea ,if all else fails take it to a pro.Good luck.
Old Dec 14, 2011 | 05:19 PM
  #15
lowlife9's Avatar
well then if everything checked out then process of elimination would say it your stock head unit malfunctioned which sucks because after doing some searching it looks like your radio and climate controls are one whole piece so going after market mite not be an option. looking on ebay they have cheaper replacements but there cheap chinese units that i would never recommend to anyone . i would try to find a used stock one either online or maybe a local junk yard either way good luck.
peacemaker69
Jun 27, 2012 01:17 PM
captmoto
Sep 4, 2010 10:45 AM
diamindzimage
Jun 18, 2010 02:49 AM
sabrev45
Apr 23, 2009 02:42 AM
JJJeff
Jun 26, 2008 11:48 AM
