Honda Odyssey 2012 Code P0522 (Oil sensor)
Old Sep 29, 2020 | 12:56 PM
KevJenn's Avatar
Default Honda Odyssey 2012 Code P0522 (Oil sensor)
Hi Folks,
Have a 2012 Honda Odyssey which began throwing a Check Engine Light and Check Oil Light. My scanner revealed code P0522 which I took to be an oil sensor.
Sooooo.it is my wife’s van. Took it to dealer and they came back with a bad oil Pressure SWITCH at $302.00 ( $71 part/rest labor) . Then the next morning they text her ohhhh…after running further diagnostics it looks like it is the oils sending unit and that is $505 ( labor $210.00/unit $293/O ring $1.75).
So I said no… grab the car and let’s regroup… which she did).
So it says on the diagnostic report I looked at ROCKER ARM OIL PRSSURE SENSOR A.
So basically the sending unit is the same as the oil “sensor” (which we thought all along).
Is this something I can do myself? I have fixed a fair amount of things over the years on cars and want to do it myself if possible.
Appreciate your time!
Kevin
Mare
Sep 21, 2017 08:29 AM
Shinmen Takezo
Dec 22, 2010 07:24 AM
Daves03
Dec 19, 2010 05:37 PM
dahuckman15
May 30, 2008 03:25 AM
trichard310
Aug 7, 2007 01:28 PM
