how to change 98 accord v6 alternator?
Old 05-22-2009, 03:27 PM
ricosuave55's Avatar
Default how to change 98 accord v6 alternator?
How do I loosen the alternator belt on my 1998 accord vtec 3.0 ?
What is the tensioner and how do I move it?
Do I have to use a torque wrench to re-tighten the belt after I put it back on?
Thanks,
Rico
Old 05-24-2009, 07:44 PM
loosen the tensioner to remove the belt. the tensioner can be viewed on hondaautomotiveparts.com go to your year and make and parts diagram. If you intend to do a lot of maintenance on your car, get a helms manual, you can save a lot of money and get a lot of info. the manual will pay for itself many times over.
Old 05-27-2009, 01:52 AM
Default torque wrench
do I need to use a torch wrench to re-tighten the belt after installing the new alternator?
Old 05-27-2009, 10:19 PM
I do not see using a torque wrench in the instructiions. but all nuts and bolts have a specific torque, so if you plan to remove bolts, read the specific torque and tighten. If you have been doing this for a long while, you will know approx how tight to make the bolts and nuts. If you are new, use the torque wrench to not break anything.
popomama
11-22-2018 08:25 AM
Ryan Stilwell
04-01-2015 01:28 PM
lucasvilla
09-01-2009 06:16 AM
Mr_Accord
04-12-2007 03:19 PM
Camel3g GT
12-31-2006 03:33 PM
Quick Reply: how to change 98 accord v6 alternator?
