ignition lock cylinder
Old Sep 2, 2022 | 10:24 PM
Meira7979's Avatar
Default ignition lock cylinder
hey guys I'm pretty new here and I was looking to see if someone can help me with my issue i have an Honda civic 2015 es and the ignition cylinder is busted not turning well enough I was calling a locksmith to see how to fix it I guess its too much of a problem so I'm coming here to see if someone can help me out I'm looking to take out the actual ignition cylinder lock cause this is the only problem I've watch videos of how to remove/ replace those but the only one I've found is for an older models of civic or accord in those old one there is two screws to remove and then drill somewhere above it to release it in mine there isn't any of those screws ( I shared some pick in the post to see) only some kind of click plastic things that attached to it and a very far small screw that almost behind the steering wheel itself that looks like it holds it as it looks right now i don't have any idea how to remove the black plastic wrap that is prob belong to the immobilizer part in order to reach the actual ignition cylinder and then from there maybe to see if there is any kind of way to remove the ignition cylinder itself if any one know how to do so please share and help much appreciation to all the reply as advance btw i can put the ignition cylinder to on position
Mcoley52
May 6, 2024 09:53 AM
adutta3
Oct 13, 2021 08:03 AM
96civick
Sep 22, 2011 05:13 PM
kaosdp
May 1, 2009 07:36 PM
cdagza
May 3, 2006 09:48 PM
