Ignition Question
Old Apr 5, 2011 | 12:56 AM
x99civicLSVtecx's Avatar
Default Ignition Question
My car just started acting up a few days ago. The car starts fine with the turn of the ignition but when i go to shut it off I can remove the key from the ignition but the car continues to run for approx, 45 seconds then shuts off. I also realized today that if i shut it off while rolling it will shut off immediately. Appreciate any incite!!!
Old Apr 5, 2011 | 07:21 AM
Welcome to the forum,Do you mean the motor keeps running or the coolong fans continue to run?
Old Apr 5, 2011 | 10:04 AM
I finally figured it out last night. The guy i bought the car from had installed a turbo timer and it was in my glove box and buttons must have gotten pressed and set it on 30 seconds.
Old Apr 6, 2011 | 03:32 AM
if you have a turbo on your engine, you need to keep the engine at idle for a few minutes after a hot run, or you will coke up your oil bearings in the turbo due to high heat. This would be after a good long run. If mostly at idle around town and a slow drive to the home, the turbo will not be so hot. Still need to cool the turbo off for min coke of the bearings.
Old Apr 6, 2011 | 10:10 AM
Na its not turboed yet. lol
88 honda preldue
Jul 25, 2007 02:13 PM
silverbullet
Jun 21, 2007 12:31 AM
michael
Jan 19, 2007 04:57 PM
derek123
Nov 26, 2006 07:31 PM
Hannu
Sep 28, 2006 02:43 PM
