I have a 2000 accord ex 4 dr ULEV VTEC
can anyone tell me what this brake fluid is leaking from what needs to be replaced to fix it?
coming from rear driver side where the parking brake spring is on the caliper
welcome to the forum. you have the caliper, brake line, or the fittings. most of the time with 19 years it would be the rubber brake line. you might want to clean the area up clean first to check. also if you plan to change the line yourself, you would like to have it clean so you don't get dirty.
It is dripping from the spring area In the picture I’ve checked the lines and they don’t seem to be punctured or cracked
