Leaking brake fluid
Old Jun 27, 2019 | 10:27 PM
Aconn6's Avatar
Default Leaking brake fluid
I have a 2000 accord ex 4 dr ULEV VTEC
can anyone tell me what this brake fluid is leaking from what needs to be replaced to fix it?
coming from rear driver side where the parking brake spring is on the caliper
Old Jun 27, 2019 | 11:56 PM
welcome to the forum. you have the caliper, brake line, or the fittings. most of the time with 19 years it would be the rubber brake line. you might want to clean the area up clean first to check. also if you plan to change the line yourself, you would like to have it clean so you don't get dirty.
Old Jun 28, 2019 | 12:38 AM
Aconn6's Avatar
It is dripping from the spring area In the picture I’ve checked the lines and they don’t seem to be punctured or cracked
Old Jun 28, 2019 | 03:43 PM
have you checked the brake like running under the rear seat area.
mayhem
Jul 2, 2019 12:32 PM
pnomaster
Sep 7, 2016 05:49 AM
stook00
Sep 16, 2011 08:52 AM
mango02
Feb 23, 2011 10:06 PM
tattoo432
Aug 12, 2008 08:39 AM
