Losing oil
I have a 1988 Honda Accord dx. 66 thousand original miles. Set for many years but garage keep. Runs pretty good but I'm losing a lot of oil. No leaks I can see and just replaced valve steam seals but still losing oil. Help
I did and doesn't seem to be at all plus it's not smoking but when I let off gas and that's only once in a while not all the time. And it runs really good except idling, it is rough at idle.
Can oil get into the gas somehow? I noticed that every time I put fresh gas in , it runs a lot better for just a short time.
only way oil gets into gas would be at the carb with the blow by. take a compression check to see if it low, if so, the engine could be burning oil. I had a 90 accord, each 2k miles added 1 qt. ground dry, no oil dripping. compression 120+. but still pass smog. no smoke out of exhaust at any rpm driving or slowing. since brand new to 180k+
